Towing
Ungawa
Just got a 22 Yukon here is the sticker it came with. Conventional TWR says 8200 lbs, but if you go to GM website says 7400 lbs. This is on a 5.3 4x4 with tow package. Something is not adding up. Can someone explain? Thanks
Brand0n
Which GM site lists 7400? 8200 is correct for 5.3 4x4 with max tow.
U
Ungawa
Also why is the convential tow of a 5.3 greater than a 3.0L?
U
Ungawa
The Diesel engine is heavier than the gas, which takes away from the trailer weight.
300 lbs heavier? I was beginning to regret not getting 3.0 but now I am kind of glad I got the 5.3. But if I had to do it again still would consider the 3.0…..its a much closer toss up know the tow rating is less. I always thought diesel meant higher tow rating. I am always learning something new.
Smityinms
