Trans. cooler
St. Louis
I installed a larger cooler on my 2001 back around 2007 that used small pieces of hose ran between the stock lines and barbs of the cooler, with hose clamps. They're still fine 12-13 years and 140k miles later
k1970
k1970
Oman
Nice! :waytogo:
k1970
k1970
Oman
BG1988
We really need these coolers here in Oman. It is very hot and dry in summers! In 2018, I climbed a mountain and the trans. temp. reached 108 C. !!
only hit 170-175F in the summer
lately it's only been 150F i can't even get it warmed up (warmed up is 170F according to the manual)
normal temp in the summer is 100-110F range
Weird. Here’s an Amazon link. I have destroyed 2 transmissions and the builder (Performabuilt) instructed me to use this on my lines and cooler. You just hook up one end to the output line from your trans and put the input line into a bucket. Hit the button until the fluid turns clear (all the trans fluid is out) and then turn the can upside down and it forces air through which removes the cleaning fluid. It completely flushes everything from your lines and coolers. I use 2 cans just because.
Lubegard 19025 Kooler Kleen Transmission Cooler Flush High Pressure Formula, 18 oz. https://www.amazon.com/dp/B073TQGYFZ/ref=cm_sw_r_cp_tau_QKn3EbXKVRMEY
The O'Reilly link worked for me.
lordmorgul
