Transfer case fluid?
F
farhanm
Oklahoma City
finally got done with the fluid change. it went surprisingly easier than i thought it would be. during the rear diff fluid replacement, i also took the spare down and cleaned/lubed the winch assembly.
so far everyting looks good. no leaks yet.
Thanks
Farhan
Rosson03
Kentucky
I did quit a bit of research many said it is a good,high quality oil. I also replaced my front and rear diff with royal purple MAX Gear oil 75W-90.
Looking to do the same..... Any regrets
Synthetic dex 6 for engine and what about syn dex 6 transmission?
buck91
Well the manual also says Dexron VI. But I have the selectable dial selector.
So that's what's confusing me.
Here's what's the manual says and a picture of the switch.
Again, I may have misunderstood, but Auto trak II was for the this type of selectable switch and Dexron vi was for AWD with no switch.
Thanks
Farhan
Looks exactly like my 2011. Manual wasn't very helpful and I became worried about it after reading some posts here for Autotrak II since I just changed with Valvoline MaxLife ATF. Well, just spoke with the local dealer who says they are calling for Dex VI.
Rosson03
Kentucky
So let me see if I got this right
75 W - 90 front and rear
Synthetic dex 6 transfer case
Dex 6 for transmission
Going synthetic blend in the engine
M3kanic
Depends if you are awd or 4wd
M3kanic
Also 75w 140 for lsd or you need to add lsd fluid to it for the rear. Most of us just use 15w 140 regular for the front.
M3kanic
If you are 4wd you use auto-trac II but if your awd takes dex VI . Unless something has changed since the last time did the research for it.
bkool
