Transmission fluid change
Bob2C
Northern VA
If anyone needs some. Was 13 bucks yesterday. 17 not bad.
smokey_mountain
I bought a very much the same Pela extractor but a) metal re-enforced tube is a bit short and it did not go into the dipstick to reach the fluid in the pan (I guess there are two tight turns; b) anyone knows if there is a longer but still metal re-enforced thin hose that we can attach to reach the fluid. My transmission is 2018 6-speed.
ladorn45
Do i use this fluid for a 2001 tahoe as well. I know 05 are the same for alot of things but just want to make sure thanks
Bob2C
Northern VA
I’m not too sure. There are others on here that might know
SnowDrifter
Washington. The starbucks side not the desert side
Go to a bicycle shop, get some of the stiff brake / shifter cable guides, cut to length, get a rubber stopper or cork that fits your flexi plastic tubing and that, press fit, and there ya go
mohammadalhashim1
