Transmission gone... does this rebuild estimate seem fair?
NickTransmissions
Sin City
The transmission bench
Scotty on YouTube warns against "trusting" any shop to rebuild your transmission.
Do you have a link to this video of his? I’d search but he’s got a billion videos on his channel so would take me forever to find it.
I’m curious as to his rationale & supporting arguments for that statement.
Some shops are down right incompetent, others are unscrupulous and some are both but many are trustworthy and do a good job for their customers.
The main thing for consumers is be sufficiently informed so they can ask the right questions so they know when to walk away if the shop’s answers don’t cut it.
Thrust
ICT
Shops will have varying rates depending on what they do to the trans, local market going rates for an overhaul as well as cost to R/R the unit to and from the vehicle.
That said, for that amount of money, I’d want to know exactly what they are doing/installing upon overhaul. It should include the following, in addition to stuff like filter, gaskets, seals, orings, sealing rings:
1. New frictions and steels - tell them you want Borg Warner or Raybestos high energy clutches and a new steel module for all clutch packs (consider a kolene pressure plate and steels for the 4-5-6 clutch pack)
2. New TEHCM, Internal Mode Switch, wiring harness and speed sensors - all must be OEM and Fast adaptive relearn performed
3. Sonnax Zip kit installed (has updated valves for the valve body and pump)
4. Pump completely overhauled (both working surfaces machined flat/true, pump rotor and slide-to-deck clearance set at .0015”)
5. 3-5-R drum re-welded at the base where it leaks to prevent recurrence
6. Sonnax 1-2-3-4 billet aluminum apply piston installed in place of factory piston
7. All brand new bonded steel and rubber pistons/piston dams
8. New OEM rear sprag clutch
9. New snap ring for the sprag assembly
10. New torque converter with .050” or thicker converter clutch - DO NOT let them give you an oem converter with the same POS .020” thick clutch as it fails repeatedly
11. Optional unless high peformance or heavy duty: Sonnax billet 4-5-6 clutch hub with Sonnax apply/dam piston kit to run an additional friction and steel in the 4-5-6 clutch pack. The OEM hub can snap in half under power
12. Cooler bypass delete kit or at least a lower temp thermostat so it runs cooler than stock
13. New, updated parking rod assembly (these were prone to failure and if that happens you lose the ability to put the vehicle into park)
What's your recommendation if say a 6.2L with a 2.3L Magnuson was attached to this 6l80e? Same parts or would you change anything?
Thanks as I'm sure mine will need a rebuild in the not so distant future.
NickTransmissions
Sin City
All the above updates/procedures plus billet converter cover and tuning to optimize trans control based on application and power levels (you may or may not need a small diameter converter depending on desired stall speed)…If you’re going over 800hp, I’d also consider installing a rear planetary carrier assembly with a billet steel drive plate.
You can also look at “all in one” performance kits like this one from Circle D for your soft parts and select hard parts. Id also install a teflon coated bushing kit (all bushings w/teflon coating not just the pump body). Also adjust front end play down to .020”-.030” from the factory set .050” via shims. This is normally not adjustable in the 6L family of transmissions as GM decided to eliminate selective pump thrust washers.
Lastly replace the IMS, speed sensors and harness w/OEM GM parts (all rebuilds, not just high performance).
Attached is the quote I received this morning, adding $500 for new Billet TC.
Have they removed it from the truck yet or dropped the pan?
They may stink at writing up estimates but do good work. The guy I would use up in your area has become a missionary and left the country! He was in DeLand.
Ask if they are using a Florida Torque Converter:
PJDYukonXL
PJDYukonXL
Orlando, FL
Yes... had it all apart this morning (pics attached).
I believe FTC is their supplier. That website matches what they sent me as the specs of the new TC.
PJDYukonXL
PJDYukonXL
Orlando, FL
Did you ask them any of the questions in my previous posts?
If so, what did they say?
Well, to say I got a little pushback from the mechanic (not owner) questioning his plan would be putting it mildly. I understand he probably gets tired of internet mechanics/ experts questioning him the same way my wife hates "Dr. Google" in her medical field.
That said, he did go through each of your questions with me.
Yes, all bushings are being replaced.
He said the pump looked to be in good shape and did not want to open it up. He claimed "tinkering" with them can cause more problems.
Is not planning to reinforce base welds.
Not using factory piston
Mechanic couldn't tell me the clutch thickness of new TC, just that it was an upgraded part from OEM. I believe it's from Florida Torque Converter
Snap ring will be replaced.
Transmission will be reprogrammed by dealer
The owner then went on to tell me that they stand by all their work and that the 40 years of business and 500+ 5 star reviews should help speak to the quality of their work. He assured me that they will lifetime warranty ALL the parts of the transmission whether they replaced the part or not (?!?).
In the end, I recognize I could probably get this done cheaper somewhere else, but am trusting his reputation that they are doing the best for me.
NickTransmissions
Sin City
Id have taken it elsewhere based on the above two responses.
1) You ALWAYS reinforce the 3-5-R drum base welds in these transmissions. Literally the number one pattern failure in these transmissions is leaking welds at the drum resulting in burnt 3-5-R clutches (no reverse, third or fifth gear)
GM introduced an updated design but still has issues. This article/video explains the problem. The updated drum has a QR code on the drum to ID it as the latest version. You may have one thus why he’s comfortable not reinforcing the welds but i do it on all of them regardless, unless it’s already been done.
2) You ALWAYS recondition the pump castings.
His response tells me he doesn’t have a vertical CNC mill which is what you need to machine the pump body. I don’t have one either but my machinist does and its extremely rare for the surfaces to still be flat/true and without scoring after 100k plus miles.
He has to open it up to change the vanes (veins) anyway.
I understand his position as i sometimes get irritated with people asking questions where it’s obvious they didnt do any research prior but at the same time, i also understand how important it is to help the customer understand what’s being done and why so he understands what he’s paying for.
This shop rep’s attitude is a big reason why I decided to teach myself how to rebuild transmissions (well that and i was ripped off by a trans shop earlier in life). There really shouldn’t have been any push back at all given what you were asking.
But if the shop stands behind their work then all you’ll be out is time w/o the vehicle if it has to go back for warranty work.
Best of luck with it, please keep the thread updated on how things go once you get it back.
mikehooo
2016 Yukon XL SLT - 95k miles. 6l80 transmission - 2 nights ago felt like it was starting in 4th gear, kept changing gears on highway, clunky shifting. Took it to a local shop and was told the following:
We have thoroughly inspected your transmission. The valve body assembly (hydraulic cross leak) and the Torque Converter(overheating) are bad. The transmission has other internal failures; ie, burnt clutches and steels.
We can fix it. The first step is to remove, disassemble, and inspect the transmission. This labor equals $1,420.00.
The range the rebuild this six (6) speed transmission is from
$5,680.00 up to $6,350.00 + taxes
The inspection labor is included in the price range above.
Comes with lifetime warranty on internal mechanical parts.
Does this seem like a fair estimate? Transmission shop has 4.9 star rating with 500 reviews in Orlando, FL.
Also, anything I should try to have upgraded at this time?
You can order a NEW trans. from on GM cheaper than their estimate to repair your old one. Just thought you may want to check into that.
ehernande86
