Thanks , will try to take a look in morning.Yes, anything in the drivetrain behind the rear ring gear in the transmission (which is where the parking pawl locks)that is broke can cause no Park condition i.e. t case diff etc or a broken trans ring gear
I will try to Check that also , thanks.then there is the infamous transfer case oil pump housing beating its way though the rear casing slowly as the fluid all leaks out till its empty![]()
I will most definitely check that also in morning. Thanks againYou could put the rear end up and listen to it in a gear that works too see how the pumpkin/axle sounds. Usually with the transfer case, the lights on the 4wd switch won't do what they're supposed to if it's trouble.
Bingo, grinding / ratcheting sound when rolling and grinding sound in reverse. That’s exactly the sounds I’m getting, and correction no 2nd or 4th gear.its odd your having a no 2nd and 4th condition AND a park issue, usually those are 2 separate issues. Generally broken ring gear and planets in the trans will cause no Park with a grinding or ratching type sound when its rolling away in Park. A broken sun shell may make a grind in reverse but won't affect Park
You guys and this site are great in assisting any all members here, glad I found this and thanks all .
