Transmission Temperature Gauge/Fluid Change
rockola1971
Indiana (formerly IL)
Good luck finding a supplier for the trans temp faceplate to install in your cluster. The guys that do it online for a fee keep their supplier info secret. Ive yet to find a supplier just for the face plate so i can convert my (2) 03 Tahoes. My 05 Denali has it factory of course.
HiHoeSilver
Away!
Chicago
I have found a bunch on EBay.
rockola1971
Oh you are referring to refacing the whole cluster faceplate(s)? Im referring to the single face plate like whats on my 05 Denali. My 03 has a seatbelt face plate in that spot if I remember correctly but it can be removed and the temp gauge put in there along with a oem or copy of oem faceplate for the trans temp.
HiHoeSilver
Away!
Chicago
Oh you are referring to refacing the whole cluster faceplate(s)? Im referring to the single face plate like whats on my 05 Denali. My 02 has a seatbelt face plate in that spot if I remember correctly but it can be removed and the temp gauge put in there along with a oem or copy of oem faceplate for the trans temp.
Yeah, I meant the whole thing. I have seen the individual ones you're talking about, but only in a whole set, and I'm not sure of whether the trans temp is there. Mine is just blank in that spot.
rockola1971
There are guys on the net that will take your cluster and add the temp gauge but I dont know where they are getting the individual temp face plates. They wont come up off with that info. That probably would put them out of business if people found out.
tdeaton3
