Transmission
RET423
I use an old transmission line with a hose slipped over the end to get it below the bumper.
The upper transmission line on the radiator is the line that returns the oil to the transmission, I just pop off that return line and pop in my line with the hose and stick a bucket under the hose.
Then I start it and run it until the line sputters, that means the pan is dry so I can drop it without mess and replace the filter.
Then I dump 4 quarts in the pan and start the engine again, I have my son pour in new atf as fast as he can pour and I watch the color of the fluid being pumped into my pail; when the dark fluid is replaced with the new pink flow I shut off the engine, pop off my drain pipe and pop on the old return line.
Then I just back it off the ramps and top off the trans normally, no leaks or mess and every drop gets changed; you will waste an extra quart or 2 with this method but it is worth it to me to get 100 percent of the oil changed and no mess on the driveway or the car ;)
allen57
