Trnasmision GonAAAA
bigJay63
2011 gmc yukon xl
transmission is slipping when it gets hot and i throws 2 codes
P0796_00 Pressure control solenoid 3 stuck off
P0989_00 Transmission Fluid Pressure (TFP) Switch 5 Circuit Low voltage
eeeeeeesd
ddddddddddoooooooooooooooooooooooooooooooooooooooooooooooooo
NickTransmissions
Sin City
The transmission bench
2011 gmc yukon xl
eeeeeeesd
Drop the pan and see what's at the bottom then refer to my 6L80 Information thread for the link to the ATSG manual so you can research those codes and perform continuity testing on the applicable solenoid and pressure switches to confirm/deny the DTCs. You'll need to remove the TEHCM to do this testing; purchase SnapOn's 10EPL socket - this is a modified inverted Torx 12 socket specifically made for GM TEHCM/Valve Body Assembly-to-transmission case bolts...Undo the white locking latch prior to removing any bolts.
mwatts32
