Trouble. Oil in radiator?
T-Bagg
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
The 2 row has a thicker core with more tubes=better cooling
Read this if you wanna save some cash and still get the 2 row
http://www.fullsizechevy.com/showthread.php?375294-Radiator-upgrade.-Sticky-maby
http://www.oreillyauto.com/site/c/s...ar=1991&make=Chevrolet&model=C1500&vi=1031252
$149 vs $229 for a radiator with the same measurements :gr_grin:
This did not work for me. The fittings between the radiator and the oil lines were different threads and or sizes. I ended up with a plain old OE replacement radiator from NAPA. Even the other radiators from O'Reilly's and AutoZone had the same fittings issues. Apparently GM uses some stupid random thread size and count. I couldn't even find a tap and dye set to rethread the fittings to match.
Carlos123
