truck is leaking AGAIN!!!!
Gzes
the drifting 2dr
Wichita tx
If u cant duck it **** it. Lol jk but yea its probably just a hose so get it n fix it
Donnie Yukonie
Donnie Yukonie
Yates Caretaker
yea i think im going to try and fix it tom maybe sun do you have a good part number? or brand
Tbruz
Windham NH
Its the heater mixer valve.
Delco P/N 12380318 about $35 from the dealership.
Tbruz
it's unlikely that the valve is actually the problem, most likely is the hoses and/or clamps but while you're in there with an empty cooling system, might as well change all that out anyways.
TORONTO 95 GT
Mine was the valve and not the hoses. Like said before, change it all and be done with it. That is what I did but even after that I chased leaks, quick connects and then the intake started weeping but not into combustion chambers or oil, just leaking to external. I have not pulled the intake yet as I will just pull the motor and either crate it or rebuild it. 95 TBI with 200K miles on it will do well holding something in the middle of the lake.
Gzes
the drifting 2dr
Wichita tx
The valve on my dads truck did the same but it broke so yea they can go bad. But hurry up n fix it don before it goes boom
hackjob1
