truck pulls to the right, even after alignment
el_flores
Mine was the cause of sticky brake calipers. Didn't know at the time, but after I fixed it while replacing the rotors and pads, it stopped doing it.
chip
Tampa
Well, I replaced my tire today and WOW! It was so much worse than I thought. I can't believe the tire didn't come apart on the highway!
Luckily for me, the new tire solved all of my problems. It drives like a dream now. No pull at all what so ever. Drives straight. Stops straight. Love it!
I would still like to know more about the keys idea though. If anybody finds out for sure. Please post up.
brassknucklemafia
phoenix
food for thought. thanks for the directions about tire idea. glad it solved your problem.
mine only pulls while driving, not during braking, like with a dragging rotor.
chip
Tampa
Mine didn't pull while braking either, but if yours is pulling only while driving, have you considered the hub/bearing assembly? That was causing mine to pull to the right a while back. It wouldn't make any sound. It would just pull to the right.
brassknucklemafia
phoenix
actually i got to thinking about that last night. i started to pick up a slight vibration, more like a pulse, comes and goes. thats what made start to think of the wheel hub bearing. i'll just replace both sides at the same time. I had one lock up on a on a vw i had years ago at 40mph, scary as hell. did about 20 donuts before i stopped. lol
oakrdrs187
Coachella,CA
These guys are right, once you have worn a tire it will still jerk to in the direction it wore even after alignment, try switching the around.
chip
Tampa
LMAO, I can see it now!
brassknucklemafia
phoenix
yeah. shop said that the road will pull one side or the other due to road crown, since tires are so wide (315's) thanks guys looking into getting bearings on both bearings on both sides done when new tires replaced.
Tssonebay
