truck pulls to the right, even after alignment
brndns_hoe
Plano, TX
so the camber was never in spec on alignment once I lowered the truck. it was maxed out. I finally got camber bushings installed to give it a couple degrees of adjustment availability, and now everything is in spec on the alignment, but it still pulls slightly to the right? can anyone think of anything else that would cause this? tires maybe?
JKmotorsports
Austin, TX
Tire pressure, bad tire, sticking brake caliper, control arm bushing(s), rear axle (thrust angle). Was it only a front end alignment or a complete 4-wheel, thrust angle alignment?
brndns_hoe
brndns_hoe
Plano, TX
full 4 wheel was done. control arm bushings....are those different than what I just installed? i'm leaning towards the tires, although I hadn't thought about the sticky caliper, is there a way to check that myself?
here's the printout on the alignment....
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Ok, try narrowing to tires. Swap front tires and see if the pulls goes to the Left. If it does you can suspect the that tire you swapped for cause of pull.
chip
Tampa
Mine pulls to the left. I got the alignment checked and they said it was fine. I'm wondering if the torsion bars could have anything to do with it. Anybody know?
brassknucklemafia
phoenix
would like to know this as well. have exact same problem. did 4 wheel alignment. swapped front to back side to side . x over every thing. still pulls. drives me nuts. thinking maybe bad tires? (i know it happen but damn 315/30/24's arent cheap). is it possible the keys are un equal ?
greenhornet
Ontario,Canada
I have experienced radial tire lead ,caused by a belt deforming under load. Most times you cannot see it but it causes the tire to pull in one direction ,as mentioned above try moving the tires around the vehicle to see if it goes away,just a thought.
chip
Tampa
Funny you mention that, because the belts are seperating on my front drivers side tire. I've been assuming that's the reason, but untill I replace it, I figure I might as well see what everyone else is experiencing.
mplanet
