Truck won't crank
nonickatall
Germany
I have a problem with my truck. it won't crank.
I had that problem a month ago as well a few times and I swapped the battery, after that it didn't happen again.
Today I helped someone who had a problem with his car. His battery was empty, so I bridged his battery with my battery while my engine was running. I checked the other car for error codes and noticed that my engine was had stopped for whatever reason.
After that i tried to crank, but nothing happens.
I thought first: My battery is low and I put on a charger.
The battery is new and now full and when I turn on the ignition, I have normal lights in my instrument cluster.
When I switch to start, I have the lights going away, like normal.
But there is no crank, so I first removed my right wheel and measured at my starter, if current is available. I can measure ground to ground and I have 12 Volt at the power line, from the battery.
On the line which controls the magnetic switch of the starter, there is no 12 Volt, when I let someone start the truck.
So I looked for the starter relay. I swapped the starter relay with the equal relay next to it, with "park lp", whatever that means. No change.
So I looked for the description on the relay and I measured between 87 an 86, but there is no current, so it seems that something else don't work.
I tried to bridge 30 to 85 but the starter don't crank as well.
When I switch on the ignition. There is this sign with the lock. I'm not sure if that is always there.
Does anybody have an idea, where I can start to search for the problem?
Best regards from Germany
Ralf
Scottydoggs
NJ
the fat cable to the starter should always be 12 v hot. the small wire should show 12 v when the key is turned to crank, its the trigger wire. so if thats got power the starter is not working, if its not getting power it could be something like the starter relay, or the fuse box melted under the relay, or the ignition harness in the steering column has gone bad.
nonickatall
nonickatall
Germany
Thank you all very much.
I have 12v on the main cable of the starter and ground from the ground cable. But on the trigger wire, i have at start no 12v. So that must be the reason for the problem.
As far as i unterstand, these trigger wire comes from the starter relay. I am not sure if something is betweeen, like the key lock system, because when I bridge 30 to 85 on the relay socket, the starter should turn, like i know that from other cars. But it dont.
As well, i have not signal on start on 86 and 87 which means the problem, must be between ingnition switch and key lock and or engine controll unit.
Hit this link for an electrical diagram, but you may need to change the link at the top, depending on your specific model. I suspect one of the ignition fuses may have blown, but that's just a guess.
Thank you very much for that info, i will try to check that.
I 2nd an ignition fuse popped. After that I suspect ignition switch on the steering column is burnt at contacts.
I found only two fuses for the ignition on the fuse box diagramm and ckecked both. Both are ok.
Is there a proper way to check the ignition switch? Is that switch available as spare part?
Also, your owner's manual will have a diagram of the various electrical centers (fuseboxes) with somewhat limited descriptions of each fuse.
Yes, ich found only two fuses, i am not sure if there a more.
nonickatall
nonickatall
Germany
Interesting fact is:
When i had the problem first, a few weeks back. The car was driving, i stopped at the school to pick up my daughter and after 5 minutes, i tried to start the engine again. My battery seems to be dead, because there was only a "click" noise from the starter. So i asked another mum to bridge my car. I have allways a starter cable in the truck. That didnt work. There was also only a "click". So i went home and come back later with a charged battery.
Strange was that the car made a alarm noise, like from the key lock system? And my Radio was not going off, when i switched off ignition and opened door like normal.
With the charged battery and after a few hours, i came back, bridged my car and it startet. But Radio was in a strange mode and the instrument cluster was dead. I had not temperature, speed, or engine rotations.
I
I drove home and disconnected the battery for a short time. I charged the battery and connected it again. After that the car startet and instrument cluster and radio was normal again.
I had that behavior another 2 times, then I swapped the battery with a new one. Since then that never happend again until now.
Any ideas?
nonickatall
nonickatall
Germany
I found something. I checked all the fuses an found a blown PCM B 20A fuse. I replaced it and the truck cranked for short. The engine didn't start, but maybe it cranked to short.
The fuse was immediately blown again.
Anybody an idea what to check?
donahuec
