Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have a '99 Tahoe LT, 5.7L. It has a place for a second battery. I'd like to use it to drive a new audio system and use as a back-up for the other battery.
you can use the info above to do it...but its easy just get a selonoid and wire like this...
1 power from front battery thru solonoid to other battery then back to your amps
MAKE SURE YOU USE FUSES
2 make sure you ground the second battery to a good ground also......
3 wouldnt hurt to do the BIG 3 under the hood either.....
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
