Update on the brake job and pedal problem
DesTRucTO
Phoenix, AZ
So i did brakes all the way around. First time turnin the rortors and new ceramic brake pads for the front, got new drums and shoes and hardware for the rears and it was only 130 at Autozone :) A mechanic buddy of mine helped me out with doin the rears and then we bleed the lines to makes sure there was no air and the pedal reacts faster but is still as sqwishy as before... he noticed lil floaters in my res. and said he thinks i need a new master cyl. :(
AtomicHoe094
Atomichoe094
cleveland, OH
yea when i got done doing all 4 corners on my truck, the rear brake cylinders blew. that suckd! maybe its time for you anyways to do the Hydroboost and stainless steel lines anyways :)
D
DesTRucTO
Phoenix, AZ
how much does the lines and booster run? i noticed atomic that we have very similar trucks... how many inches is the top of your fender well from the ground? mine stock sits at 36 level and i wanna lower mine but dot kno how much...
AtomicHoe094
Atomichoe094
cleveland, OH
not sure on the booster for ya. the lines i bought in a huge roll then did everything my self. put all new fluid and shit in them.. ill go outside and measure them right now.. is yours 36 at all 4 corners??
wait fender well?? like the top most part of your fender on the outside of your truck right? the lip??
and im at 31 1/2" all the way around....
D
DesTRucTO
Phoenix, AZ
ya the lip lol my bad... wel i measured again and im at 32 all the way around but i kinda wanna drop it like an inch.
bowtiefreak
No Quarter
Near Philly
Are we talking fender heights or brakes? If you are getting a new master clylinder get one off a newer NBS, I am told they fit. The bore is larger allowing more pressure to the brakes. Also if you want, look into the firm feel master cylinder from SSBC
BurbyRST
