Im looking to do the same thing, swap an 07 nav from my sierra to my 07 bose but non-nav yukon, also looking to add an oem backup camera to the oem nav that i put in the yukon, i think i have the head unit part figured out as fair as adapters and unlocking, but not sure on connecting the oem backup camera.
Sent from iPhone 7 plus using Tapatalk Pro
Gonna have to have the backup camera feature enabled when it's programmed to your VIN, then you can turn it on or off as you wish in the Display menu. The connector that you'll need that has the wire to tap into the VSS harness also has the camera input. It's an RCA plug so you can use an aftermarket camera and simply plug it in. I don't recall which brands or models specifically are best, but I do recall reading that there are a few aftermarket cameras that are superior to the OEM camera and they're cheaper.
