Upgrading the steering wheel. Adapatability question
2DR4EVR
Texas
Is it possible to put a later model steering wheel on an older car?
Mine is 1996 LT. I've redone the inside except for the wheel. It's pretty crusty and doesn't really look at home anymore.
Pretty costly to recover. Looks cheaper to replace in most cases.
I really like the Grant Revolution style. (link below)
http://www.carid.com/2011-chevy-tah...r-bag-replacement-steering-wheel-4236681.html
So would this work? As in will it bolt on to an older Tahoe? I realize the buttons on the wheel will obviously not be hooked up but it would be nice to retain the function of the airbag. Would there been any issues with self terminating blinkers not function etc etc.....
2DR4EVR
2DR4EVR
Texas
Ha.....thanks Sunlit. I may just go ahead and order it. It's half the cost of a recover so if doesn't work out I can send it back.
I read a review on that wheel from a guy who put one on an 89 Camero so I think the chances are good.
Ill report back when I get a chance to order and install it.
AZ Tahoe
Arizona
That website says the wheel isnt available. Where are you buying it from
kses123
kses123
Raleigh, NC
You could probably do one that had a single stage airbag. That would be up until to 2002 models. 2003 later became dual stage air bags. However, after 03, there are some 2500 and 3500's that have the new style airbag but it is still single stage. Some of the expres Vans are the same way.
You can tell on the back of the airbag if it has one vs. two connectors. Two being the 2 stage airbag.
Gzes
the drifting 2dr
Wichita tx
It should work. A while back timmy had a wheel that said it would work
marktorres4242
