Vanquish Auto 80w PHILIPS LED Fog Light Bulbs PSX26W Review
burbplayer
Here is where I got all the lights for my truck just in case you guys wants some of them
LED Backup Lights
http://vanquishauto.com/back-up-light-bulbs-7657.html
High Beam and drl
http://vanquishauto.com/9005drl.html
License Plate
http://vanquishauto.com/2008-2016-buick-648.html
Brightest Fog Lights
http://vanquishauto.com/2015-2017-gmc-yukon-xl-super-bright-led-fog-lights-353.html
Regular Fog Lights
http://vanquishauto.com/2015-2017-gmc-yukon-xl-super-bright-led-fog-lights-354.html
LED Low Beams Kit
I will recommend everybody to buy their lights because they are extremely nice and bright to drive with. They have the brightest lights. I am 100% a happy customer of www.vanquishauto.com
16blkltz
Denali132
Banned
Still trying to find a shop that will put in my Vanquish Auto HID lows and LED high beams! The body shop won't do it. I need to find a place that I know will do a good job and install them right
Sent from my Samsung Galaxy S7 Edge
WillieFlo
Houston, Tx
I'm not sure a north/south versus an east/west LED orientation will cause more of a blinding light for the same powered lamp within the same housing. The in-direct disbursement of these lamps are caused by the inherent design of the fog light housing/reflector itself. These housings are specifically designed to produce a very wide horizontal and narrow vertical pattern.
If I was to guess an east/west orientation of these 80w LEDs would be a little brighter, since the LEDs would be directed towards a larger portion of the reflector within the housing, but I'm not sure they would be less intrusive to oncoming traffic. As they are, these 80w LED lamps appear visually less blinding/intrusive than the stock 25w halogen bulbs and the 50w LEDs compared here (which both produce some direct light toward the oncoming driver). This is where I believe you will find the greatest benefit to oncoming traffic - not having a direct light source (halogen bulb, or LEDs facing forward) pointing towards the oncoming driver.
I did just look up the VLED bulb you referenced and they do mention the reason for the new rotatable/adjustable base version is "for proper LED indexing in the lamp housing". Which is what I mentioned earlier, to align the LEDs towards the largest portion of the reflector in the horizontal position.
I would definitely be interested to see some side-by-side comparisons of LED lamps with adjustable orientation for both light output and glare.
bzpilot,
I'm going to be receiving these (Car-Lighting-Source PSX26W 80W 4000LM each bulb) sometime soon, which are designed almost identical to the Vanquish Auto, minus the Orange metal tip(All Silver). They have the 4 Philips LUMILED chips in the same orientation with the same spec's, even down to the 2 Yr warranty. When I install, I will photograph 1 bulb in the N-S orientation and 1 bulb in the E-W orientation to compare and post. I went with the C-L-S version because they were only $83.60 with FREE SHIPPING versus the $120+ for the Vanquish with equal spec's.
burbplayer
I'm interested because I'd like to upgrade my 2016 Tahoe.[/QUOTE]
They are both good. There is one that's is regular led for less price and still give you a great results of brightness because they have the 80w brighest ones and the other ones are the full led fog lights kit 6200LMZ "i believe those are the brightest fog lights leds you
burbplayer
http://vanquishauto.com/2015-2017-gmc-yukon-xl-super-bright-led-fog-lights-365.html
These ones for $199.99 are brighter , i have tried the other ones in the past and they were still incredible, but wanted to give a try to the new ones they recommend me and i really can say these ones are a lot brighter, 3x times brighter and whitest too.
http://vanquishauto.com/2015-2017-gmc-yukon-xl-super-bright-led-fog-lights-367.html
I also find out that on eBay there is another seller with some similar leds to the vanquishauto brand and i made a comparison so people don't lose the money buying a replica lights when they can buy the original ones from vanquishSlide1.jpg
burbplayer
bzpilot,
I was looking at the ones you already bought and i compared those to the ones i bougth from vanquish auto., and here is the details., I still believe mine are brighter than those you bought! I always compare all options are on the market so i get the best ones.
http://vanquishauto.com/2015-2017-gmc-yukon-xl-super-bright-led-fog-lights-373.html
  • Lumen: 8000 LM per bulb
  • Power: 80W (40W per Bulb)
  • Voltage: DC12V-24V
  • CAN-BUS No error codes on dashboard
  • 3 years warranty
  • LED Quantity: 16 PCS( 8PCS-PHI on each bulb)
  • Beam Angle:360
  • Input: 2.0A±0.2A
  • Heat Dissipation Theory: Heat Pipe Technology + A380 Aluminum Heatsink
  • Operating Temperature: -40 - +80℃
  • Application: Fog light-headlights
  • Operating Life: >50000hrs
  • Lastest conception design, smaller size,No fan,wide heat dissipation area, high heat conduction
  • Simple installation - Plug & play no relays - No wire cutting
  • Waterproof
https://www.carlightingsour3.com/pr...-philips-lumileds-psx26w-8000-lumens?variant=
Specification:
Lumens: 4000Lm Each Bulb
Wattage: 25W Each Bulb
Waterproof: IP/67
Aluminum: 6063 Aviation
Chipset: Philips Lumileds
PCB: On Board Driver
Non canbus
Warranty: 2 Years
Vinvin7716
Got the 80w bulbs installed. For the guys that have them.. are yours not as snug as the oem? I've tried to reposition handful of times but still isn't as snug. I can still wiggle it, but it doesn't come out.
eb5665
