Vanquish Auto 80w PHILIPS LED Fog Light Bulbs PSX26W Review
burbplayer
I have posted some pictures already of the results with their led lights , you can see them in my previous thread. It's all 8000LMS
BADRIDES
I have vanquishauto leds, they have 1 kit 9005 that is 8000LMS. im sure they can have the same kit you need in 9006 with the same lumens., you should contact them for that, but I haven't seen anything better than their lights.
Contacted them via chat and a guy showed me some 3600 lumen lights for $124.99 and thats too much for that amount of lumens. Show me the kit that has 8000 lumens per bulb.
BADRIDES
burbplayer
Just talked to somene from vanquish via chat and he couldn't give me any kind of link to show me the lights but wanted to send me an invoice for the lights. Website is not very user friendly to see what they have to offer for my particular year Tahoe.
Well when i decided to purchased the lights from them, they sent me all the links for all the items i was looking for, however here is the link for the one you say you want 9005/9006
http://vanquishauto.com/9005drl.html
burbplayer
I am keeping eye on them because they are making some new led color change for the underground of my yukon. They havent make them yet but they told me in about 2 weeks they will be ready so I can be able to purchase them.
burbplayer
burbplayer
Find me the 9006's and the fog lights which are 880's and i'm set.
Hello, you have to contact them for those items you are looking for. But i went to their site yesterday and yes they were doing some changes to the site, but still was able to find the lights you want.
WillieFlo
Houston, Tx
Thanks for the info. I saw your comparo below and did more research, so I ended up buying these instead..... http://www.genssiled.com/shop/elite-led-headlight-conversion-kit-6000k-bulbs-8000lm/ ......no install/tab fitment/connector fitment issues or reason to question their intensity. They use Phillips Gen 7 Luxeon Lumileds and are "supposed" to be rated at 8000 LM as well. All I know is that they are pretty darn bright.
I was looking at the ones you already bought and i compared those to the ones i bougth from vanquish auto., and here is the details., I still believe mine are brighter than those you bought! I always compare all options are on the market so i get the best ones.
http://vanquishauto.com/2015-2017-gmc-yukon-xl-super-bright-led-fog-lights-373.html
  • Lumen: 8000 LM per bulb
  • Power: 80W (40W per Bulb)
  • Voltage: DC12V-24V
  • CAN-BUS No error codes on dashboard
  • 3 years warranty
  • LED Quantity: 16 PCS( 8PCS-PHI on each bulb)
  • Beam Angle:360
  • Input: 2.0A±0.2A
  • Heat Dissipation Theory: Heat Pipe Technology + A380 Aluminum Heatsink
  • Operating Temperature: -40 - +80℃
  • Application: Fog light-headlights
  • Operating Life: >50000hrs
  • Lastest conception design, smaller size,No fan,wide heat dissipation area, high heat conduction
  • Simple installation - Plug & play no relays - No wire cutting
  • Waterproof
https://www.carlightingsour3.com/pr...-philips-lumileds-psx26w-8000-lumens?variant=
Specification:
Lumens: 4000Lm Each Bulb
Wattage: 25W Each Bulb
Waterproof: IP/67
Aluminum: 6063 Aviation
Chipset: Philips Lumileds
PCB: On Board Driver
Non canbus
Warranty: 2 Years
eb5665
