Very Hard 1-2 shift, Service Stabilitrak Light
dlktahoe
Elizabeth,
I am working on sending you a private message. Thank you for contacting me, we shall see if anything comes of it!
sjg1234
Okay Forum members, please help. 2007 Denali 88,000 miles I got a message "service stabilitrack" , followed by a the blinking engine light. The engine Started shifting gears and then message said "engine running on reduced power" and then promptly died on me in the middle of the highway. I have not had any problems with vehicle up until now. Pulled over safely to the side of the road and tried to restart. Nothing. Still had power, but would not turn over. Had to call a tow truck to tow me 25 miles back into town and it is currently sitting at the Chevy dealer. Any suggestions as to what this might be and is it covered under warranty? TIA!
---------- Post added at 08:50 PM ---------- Previous post was at 08:41 PM ----------
Started yesterday afternoon on my way to an emergency farm visit (I use the Suburban for my VET practice.).Lights indicating Stabilitrak and traction controls are now off. Then they go out, then back on four times will driving down highway at approx: 55 MPH. Then it stated to service, which would go on and off. Then finally all off and everything was fine by the time I made it to the farm.
2 hours later, with a very ill animal in back that needed emergency surgery, the same happened again on way to office an hour away. Will lights were blinking on and off , the truck became sluggish and then the steering locked up and then released , after that I tried to pull over and the brakes failed for about 15 seconds, then started working and the truck stalled and would not restart. Thanks to several people, they helped me push the truck off road. Meanwhile having an assistant rush to come and get me and the dying animal. After thirty minutes of trying to keep the animal alive: I tried to restart the truck and it would turn over and would continue trying to crank itself for a solid minute with out me turning the key. after three attempts, it started and no lights and ran great: But, with all the loss time, by the time I made it to the clinic and prepped for surgery the animal died. That 45 minutes of truck trouble has caused me to lose a clients animal , that I could have saved.
This morning, the truck started with no problem. Then at clinic, I go out to start and it did the continual starting sound for about 45 seconds and then it started, but, when drove down the road, between first and second gear a loud boom and jerk and the gauges went haywire and the stereo went to full blast and the brakes quit. This is obvious a very dangerous occurrence that could be deadly.
After searching all the forums etc, this same exact problem is happening to many 07 and 08 tahoes, yukons, denalis, suburbans,silverados, cadialliac xts and envoys, But, to no avail: the solutions that seem to be a multitude of try and see attempts with great costs to the owner that does not seem to work. I do not want to go thru weeks and weeks of attempts of replacing this and that in which does not fix the problem. Also, it is troubling that with hundreds affected, Gm nor the dealers have a solution. This to me is a potential life threatening defect if steering or brakes fail to work properly, especially if it happens at higher speeds as it did with me.
Is the Body Modular sensor truly the culprit? Has anyone really gotten the problem fixed? I want to be able to take it in, but, want to have the solution or the recommendation for the repair center to follow. After talking to three service center associates at three different dealers, all three said they have heard of the problem many times, but have no idea how to fix it...Really!? If lives are lost due to the dangers this proposes, I am afraid it will resemble the Toyota Brake fiasco.
How many vehicles does it take with the same exact problem and dangers before a recall is suggested?
Thank you all and I love Chevrolet, but, this needs to be addressed.
If anyone has had a successful repair, please let me know what you had done. thanks all!!
This same thing happened to my vehicle just a while ago, but I was unable to get it restarted. Have you had any luck with repair and what was the diagnosis? Thanks!
GM Truck Man
GM is not helping
dlktahoe,
I am glad to hear that you got your vehicle fixed. If the throttle body falters again, please let me know.
Thank you
Elizabeth, GM Customer Service
---------- Post added at 11:17 AM ---------- Previous post was at 11:12 AM ----------
GM Truck Man,
I am sorry to hear that you are experiencing these issues. Did your dealership give you a diagnosis for your Service Stabilitrac and Service Traction Control light issues?
Thank you
I have spoken to you guys at GM and the dealer so many times And have gotten nowhere. Every time I call GM I get someone in Argentina who calls the dealer and the dealer tells me to bring it in for service again. Each time they find no problem. I drive it, the shifting and the oil consumption issue continues and we call GM and start this process all over again. Nothing is ever fixed and instead I waste unnecessary time and fuel driving the vehicle in for them to do nothing. As an owner of many GM vehicles I am now hesitant of another since I can't even seem to get one JUST ONE GM employee in the US to talk to me. Is this is South American auto manufacturer now.?
GM Customer Service
Michigan
GM Truck Man,
I completely understand your frustrations with this issue. Has your service technician rode with you to feel the issue you are experiencing? Do you remember what your case number was when you spoke with the Customer Assistance team? I can request that you speak with someone from the U.S.
Thank you,
smurfskier
I had the same issue you guys are talking about with the stability trak light coming on and shutting it off. After replacing two wheel bearing/abs sensors it actually ended up being a bad battery. Evidently I had a bad cell in the battery and when the rpms on the truck would dip it would do something to the computer and set off the lights. Not sure if this will work for you ..... But did the trick for me.
bcobb
Hello everyone,
Like a broken record, I am experiencing the same issues with my 2007 Yukon Denali XL. "Service Stabilitrak" and "Traction Control Off" lights will light up from time to time at random. It has happened at idle and when driving. Usually when it happens I am unable to use reverse (if idling) and if it happens when driving, my transmission won't shift gears at all. I've noticed that the underscore light beneath the gears on the dash disappears at the same time. So if that is gone, the only thing I can do is pull over, shut her down and restart her. From there all is well and it takes a couple days for the codes to clear and my dash lights (tranny and stabilitrak) to go off.
I guess I should take this into the dealer, but I'm hesitant to start shelling out money at what it seems like a problem that has been fixed by a lot of different and unrelated solutions (battery, bearings/senors, throttle body).
I know Elizabeth will tell me to take it to the dealer..so I guess I will. Anything that you can do to make this a little easier on my Elizabeth?
Thanks in advance!
-Bryan
xander569
This is an interesting thought... My 07 battery is now over 4 years old which is about their life...
I've been having this problem but only when driving on the highway and I haven't had any transmission issues when it happens. Seems like there is definitely more than one cause/solution to the issue, and more than one degree of how bad the problem is.
Metro
Los Angeles/NYC
I think it is crazy how common this problem is amongst us Denali/Escalade/Tahoe owners. I have read numerous times from Elizabeth asking if we have had a tech from the dealer ride with us to identify the problem. I think that part of this problem is that the "Service Stabiltrak/Traction Control" happen completely unexpected and randomly and by the time if we are towed the problem is gone.
I have had my 2007 Denali to the dealer for this problem 3 times in the past 12 months and every time they can find nothing wrong. I really like my Denali but I am dissapointed with the consistent problems which still remain in question. I think that I will probably buy a Range Rover to replace the Denali.
GM Customer Service
Michigan
Hello everyone,
Thanks in advance!
-Bryan
Please keep us posted when the problem has been taken care of.
Thank you,
Caron, GM Customer Service
---------- Post added at 02:19 PM ---------- Previous post was at 02:01 PM ----------
Has the dealership involved our Technical Assistance?
Thank you,
xander569
You think these trucks have problems... You will be at the dealership once a week with a Range Rover!!!
randallwhitt
