Vibrations maybe bad motor mounts
sctrl
sctrl
SoCal
IMO, the left one is bad and the right one is weakening. Not as bad as left but will follow soon.
My 05 Z71 is having me go thru a bit of hell right now with the mounts replacing, see my build thread, but yours may have better access or worse. Others here with an 07 and newer will know.
Wow so your thread. Lots of work!
Basically time for me to replace both. Thanks.
wsteele
I have OBDLink MX+. No fault codes. Are you talking about real-time monitors?
Not the monitors, it generally can be found in something called like "Live Data". The misfire counts stored will be there by cylinder. Many might have some misfires, you are looking for the ones where the counts are way above others.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
While waiting to do the mounts, make sure to accel lighter than normal, in reverse or drive.
Start looking thru the threads for 2007 and newer mounts replacement and others will also chime in with opinions.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
What @donjetman said about the trans mount. I forgot to recommend. Good call.
At RA: https://www.rockauto.com/en/moreinfo.php?pk=6437988&pt=5552&jsn=715 for $77.79 Plus shipping and use RA 5% discount code.
At RA: https://www.rockauto.com/en/moreinfo.php?pk=9353684&cc=1441039&pt=8616&jsn=966 for $20.79 Plus shipping and use RA 5% discount code.
At Amazon: https://www.amazon.com/ACDelco-2584...ild=1&keywords=25847739&qid=1625612474&sr=8-3 For $90.05
At Amazon: https://www.amazon.com/ACDelco-1581...ild=1&keywords=15813693&qid=1625612529&sr=8-3 for $33.79
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I saw RWD and clicked on it and never thought of the 6 speed.
I have no idea if it will. Post the last 8 digits of your VIN and maybe @915_Tahoe will chime in with his great info on parts for the rigs here. Give him a little time and he will likely respond asap. He will know the correct number for the trans mount and then you or I can find at RA or Amazon. Patience will give you the best results.
I just now decided to take the updated engine info and looked at RA. The mount for the 6 speed trans and the 4 speed trans, RWD, shows the same number at RA for both. But I would let @915_Tahoe do his thing to be 100% for sure.
sctrl
sctrl
SoCal
Sorry for the confusion. The link I posted was actually for the engine mount. I thought it was a tranny mount since it said in the description "RWD; 6 speed Automatic trans."
So everything is good, the tranny mount is the same on 4 speed and 6 speed, $20.
Thanks for your help, much appreciated.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
The good thing is that they are listed as Genuine GM parts.
Do yourself a favor and post your engine size in your signature for future reference.
sctrl
sctrl
SoCal
I’m using OBDLink app and I couldn’t find Live Data or anything about misfires except in the emission test section where it has a check mark next to misfires.
I did ran the real time monitor and at idle RPM fluctuates between 600 and 670, saw 700 once. Is that ok? I can feel vibrations through break paddle when it goes through fluctuations.
wlivsey
