VLEDS V3 TRITON WHITE
Samsquanch
Manitoba, Canada
I was just about to buy a series of V3 tritons for my front DRL and signals since I have them in my tail lights... I looked up front and it didn't look like there was enough clearance to support V3's without them bumping into the radiator mount. How was the fit? Was it tight or did it go in without any modifications?
brockjhammer
brockjhammer
Marietta,Ga
Drivers side was a breeze. The passenger side i had to remove the blue screw on piece on the LED housing, use the thinnest rubber washer and remove a bolt that holds on a bracket behind the headlight housing...you will see which one when you go to do the install. Nothing major and they look schweet.
NVDISZ71
Did you need the VLR resistors for these to work on your Hoe?
Chadly14
