alaska_guy
Battery light is indicating an issue. You need to load test your although and battery, voltage measurement isn't enough.
It’s been doing this for a couple of weeks. Up and down at diff. Times.What is the voltage of your battery after 12-24 hours?
Agreed! Hopefully tomorrow.Battery light is indicating an issue. You need to load test your although and battery, voltage measurement isn't enough.
Anyway to test it other than replace it?I have had this problem and it turned out to be he voltage regulator/alternator. Put 2 AZ reman alternators on before I threw a fit on the 3rd one and had them replace it with a NEW one.( the reman ones work for a week or so then went bad) The new one has been ok for a few months now.
31.5 v on A/CTurn your voltmeter to AC. See if you show any voltage.
Most likely the voltage regulator is going bad.
