Want an OBD scanner, recommendations?
ukemike
NorCal
I would like to get an OBD2 scanner for use on my 2002 Suburban. I have some issues with the ABS, and in general I would like to be able to access as much functionality as possible without spending a fortune, and reading ABS related codes is a must.
Does anyone have any thoughts or recommendations they would share?
Some of the ABS functionality will be dictated by whatever app you use with the dongle. For instance, with my OBDLink MX+ I use the supplied app (OBDLink) for my Ford, but Torque Pro (Ian Hawkins) is what I use with my Hoe. I can't tell you if the MX+ reads ABS codes, though.
Matthew Jeschke
Sahuarita, Arizona
Bidirectional? Or just one to check codes / read?
I have a generic Bluetooth dongle to read codes. You plug it into the diagnostic port and connect with phone. I use Torque Lite as a scan tool. Works like a champ, fits in the glove box. I only wish there was an option for one to build into the dash.
For bidirectional stuff I'm cheap. I a generic VCX Nano cause it came with Tech 2 Win. I also have HP Tuners adapter and VCM scanner (software). Not sure if you need a license to scan.
Lastly, you can do bidirectional with these, or just use them as a scanner. If tech 2 hadn't come with the VCX Nano I'd have bought one of these...
filthysuburban
East of seattle in the sticks
I have the obdx pro vx, haven't used tech2win but it's supposed to work on these (I also have a tech2 clone). The pro vx dongle also has a generic bluetooth odb adapter mode for any car which is nice for the price. I got it to flash tunes though.. I would recommend it if you don't mind fiddling around with a laptop or phone and want to save some cash, otherwise a real bi-directional scan tool or tech2 clone might be easier (less laptop fiddling) way to run your abs pump.
ukemike
ukemike
NorCal
The Tech 2 that everyone refers to. Is this a clone of it? Could that have similar functionality? The price seems reasonable compared to even a single visit to a mechanic. It seems a real GM Tech 2 is hard to come by and expensive. Figures. There is a green and black Bosch that seems like a real Tech 2 clone but it is also quite pricey. I am interested in a 2 way, and I guess I'd rather have a handheld unit that isn't wireless and that has as much of the GM specific capabilities built in. Under $300 would be great. I've looked at lots but they all make various claims and it's hard to tell which of them a blowing smoke and which might be useful.
I have a bluetooth dongle that I got for some other cars and for when I was doing my used car search. I have tried a few some phone apps. I found an app that reads most of the honda hybrid codes, but I am not generally impressed with the phone apps.
PS thanks for the replies so far, sorry it took me so long to respond.
2006Tahoe2WD
Silicon Valley
I just ordered a Kingbolen K7 after watching too many YouTube videos. We'll see what it can do with my 2006 5.3 non-flex. I want to see if there are more PIDS that can be graphed compared to the usual. Also I'll confirm what two-way functions/tests are available. I can report here or some other place - depending on what people want. I had a Foxwell NT510 Elite but it had a hardware issue and I got my money back.
there is no need for a original tech2, the clones do the exact same thing
the only difference is the clone has a inferior power regulator, so if you need to cycle the key for specific diagnostic purposes it will instead reboot.
the fix for that one issue is to simply plug in a 12v dc household power adapter and you are golden.
clones run around $300-350
2006Tahoe2WD
Silicon Valley
Innova 3100 if you just want to read/clear:
5610 if you want bi-directional:
The 516 looks good. Not a big screen. I'll see how I like the Kingbolen. I like that the Innova seems to have good USA support.
stking
