Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
yes you can lower a 4x4.
suspension work generally shouldnt be issue w/ warranty.
i have lowered mine & was able to get an MRC shock replaced under warranty
power steps as mentioned above, could be an option too
Generally the 2wd and 4wd are about the same height. Step bars or power steps are the easiest way to go. You can lower it 2 inches in front and 3 in rear without a lot of trouble. I did the same bc my wife is 5’1” at most. It did the trick but I also have running boards.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
