Weird noise?? Alittle Help possibly on problem
WHITEOUT
Dont Hate-Appreciate
Phoenix
So yesterday I started hearing a weird noise coming from what sounds like the rear driver side wheel, but may be the front. I thought it was my brake pads needing replaced, but the noise doesn't go away with brake peddle applied. Then, when I turned right, it seemed to go away for a second until wheels were straightened, which made me think it was coming from the front.
It sounds like a very light squeeling, metal rubbing, kinda like brake pads going bad, but not very loud at all. Which made me think it is my front bearings/hubs going bad since it stopped once I turned right.
Also, if I hit the brakes hard and come to a stop, when I let off the brakes lightly, just alittle roll, feels like a "clunking", almost like wheel got stuck backwards, then let loose once brakes were let loose alittle. Is this all signs of a bad front bearing/hub?
Any suggestions??? What would a hub/bearing going bad sound like?
I plan on taking it to the shop next week, since I need my front lower ball joints replaced, so I will ask them. But am hoping for some possible solutions prior to taking it in.
FLHOE
Florida
I have the same problem. Did you find out if it is the hub or was it another issue?
clean02tahoe916
Nor Cal
i had what sounds like the same issue. it was in the rear on the driver side. it is the inside emergence brake shoe. I thought it was the backing plate. I litterally cut the backing plate off. Then i found out from a friend that it is the emergency brake. put new shoes in. the noise stopped.
FLHOE
Florida
For the cost and the work, I will replace the e-brake shoes to see if that resolves the problem.
FLHOE
Florida
When I drove to work today, the noise is from the front tires and sometimes I can feel it in the steering wheel. Is there a way to check the hubs are worn out?
chip
Tampa
that sounds like a wheel bearing to me!!!!
Thumper8302
OKC, OK
just jack up the front and grab ur tire and see if u can wiggle it... it should be nice and firm.. if it wiggles u got a bad hub or bearing
Boomer73
Boom Boom
Crownsville, MD
Sounds like wheel bearing to me too. When you hear the sound, is the sound oscillating (whup, whup, whup...) or is it a constant metal-on-metal grinding? Please confirm that you are hearing it when you are NOT braking.
-B
chip
Tampa
if it goes away when you turn the wheel (with or without braking), then it's 99.9% the wheel bearing!
mello1420
