Weird noise coming from rear advice please
06xl
MD
So I've noticed a weird sound coming from the rear short of rubbing noise like metal on metal but very very faint when turning right and vehicle is in motion. It sounds like its coming from the rear brakes. I tried lighting holding brakes and not holding brakes when turning I hear it either way. I'm clueless also after 1000 miles on new pads I still smell that usual brake pad smell when having new pads is that still possible after 1000 miles??? I want to say the smell is mostly coming from the rear possible brakes stuck? Holding? And if so I don't feel it at all maybe cause its the rear brakes and they are not as strong as front?? I've put the car in drive no gas and it feels like its moving freely with no noise unless I turn right.
Thanks in advance
Rivieraracing
Have you tried messing with the parking brake when it's making the noise? It's a different set of drum pads within the same rotor and might be dragging or loose!
Mac
NY
Sounds like a stuck caliper due to brake hose collapsing on it self.
Change brake hose.
Check Caliper and guide pins for free movement.
06xl
06xl
MD
Yeah i know what you talking about when I change rotors I seen the shoes they were in great condition and snug in there place unjust sprayed brake cleaner and moved on and to answer your ? No I have no tried messing with it it works good holds tight Sony don think that's the issue
06xl
06xl
MD
Change brake hose.
What do you mean by brake hose collapsing on it self? And I will check GUide pins for movement and let you know the results.
chevyboy831
you sure its brakes and not sway bar bushings? like a squeek? not trying to be a smart ass. ive run into a similar condition on a few gm's where its worn bushings.
06xl
06xl
MD
It's deff not a squeak I'm sure of that.ots hard to describe the sound metal to metal is the best way I can put it on the other hand it not that metal to metal you hear when your brakes are shot no were near that sound just a faded metal to metal sound
M Hankel
Vancouver, WA
Metal to metal can be different things. Is it a clunk, bang, ping, or scraping noise?
Mike
06xl
06xl
MD
I would say scraping but that word makes me think of worn brake pads hitting rotors which the sound is no were near that.
chevyboy831
hmmm... maybe brake hardware rubbing? did the hardware get changed when the brakes were done?
JoeR4065
