Weird sound/bump
mmeachem
Weird sound/bump when I stop then go. It's coming from rear driver side
mmeachem
mmeachem
Bumpity, Bumpity, Bump
mmeachem
mmeachem
Thanks lemme check that but I thought it may be the brakes
Rivieraracing
Take your rear tires off if you are hearing the sound from the rears and make sure the pad isn't off of the caliper due to the pads being so worn down!! I had that problem months ago and it did what you mentioned except it would do it when I backed up! It will be obviously off it's track in the caliper if that is indeed the problem!
---------- Post added at 07:37 AM ---------- Previous post was at 07:34 AM ----------
As for mine, mine would be a very noticable thump and could feel it through the truck, as if I'd hit something small with the truck. Also would get feedback in the brake pedal when it would happen, especially when i backed up! Hope this helps!
MushroomMario
