Weird Tire Wearing and Weird Steering Response
PUGLIA
Oklahoma
Check your wheel hub. Jack your front tires up. You can do them individually. Grab the top and bottom and see if you can get a wobble or play. If so your hub is bad. My tahoe used to skate as well. Easy test to see if that will solve the problem before you go down a rabbit hole with your front end. Not sayin the others don't need to be checked. But a hub will cause steering problems like following ruts or " skating"
-----PUGLIA-----
DCT
It's been a long time but wasn't there a dealer tsb for this? Possible recall? Call the dealer with your VIN.
Jamoo
