Well crap...nicked aluminum heater line
mijohnst
mijohnst
Can see the o-rings here. I loooks like it might be fine depending?
I tried it anyway just because I was curious and it leaked. lol I'm glad I tried it though because I would have always wondered. I took it out and put in my backup plan with the piece I cut from one in the junkyard with rubber tubing and hose clamps. It seems to be working just fine and the tubing is snug. Here is a picture of that.
Now on to my next issue... I was testing the heat to make sure all works the back is not. The front works great but the back blows cool air. I let it run for about 30 minutes with the air blasting in the back on full heat but it never warmed up. I noticed that only one of the lines running back there is getting hot. The one that I repaired is warm, but not hot like the other one. I just bought this Tahoe and I don't know if it's wasn't working before I bought it. All tubes have coolant running through them so I'm wondering if the actuator or the controller in the back are bad... From one thing to the next. lol...
mijohnst
mijohnst
I'll give that a check tonight and get back here. Thanks for the help!
mijohnst
mijohnst
I haven't been home to check this yet but I do have a question. The T connectors for the heater core coming into the engine compartment (where the two relay lines run) are they supposed to be the same, right? They aren't two different types of connectors, are they?
HiHoeSilver
Away!
Chicago
The ones by the firewall next to your trans dipstick? They are 2 different fittings. One black, one white.
mijohnst
mijohnst
Well, crap...that's my issue. I bought two black ones. :/ . I'm a dumbass...
Lukestdenis
