Well crap...nicked aluminum heater line
mijohnst
mijohnst
There is always those aluminum ones from Gruven Parts for $75 each. They don't break down the road.
I have to agree. I don't like those Dorman replacements. I can't tell you how many times the stupid o-ring fell out and I'd have to go search for it.
One tube is hot
The other is cold
No warm air, correct?
Is the tube warm at the back of the vehicle? You can crawl under by the RR tire and feel. They run all the way back by the frame rail
Trying to determine flow vs. conducting heat from coolant passing nearby
in normal operation both would be hot, if one was cold then that would mean the heater core is plugged/clogged and the coolant could not flow in & out, same for the rear heater core which is where those lines go that is why there a "T" there. I guess theoretically one might get slightly cooler than the other once it has passed thru the heater core fins but it wouldn't be much.
BG1988
I can pull an entire line off of a junker but I think it's going to be a nightmare to pull one out. :/ Isn't it one continuous piece from the front heater core to the back one?
you will need to weld (soldering)it but being aluminum good luck...
I mean they do solder A/C copper pipes can't see why you can't do it with Aluminum
Black Limited
I tried it anyway just because I was curious and it leaked. lol I'm glad I tried it though because I would have always wondered. I took it out and put in my backup plan with the piece I cut from one in the junkyard with rubber tubing and hose clamps. It seems to be working just fine and the tubing is snug. Here is a picture of that.
Now on to my next issue... I was testing the heat to make sure all works the back is not. The front works great but the back blows cool air. I let it run for about 30 minutes with the air blasting in the back on full heat but it never warmed up. I noticed that only one of the lines running back there is getting hot. The one that I repaired is warm, but not hot like the other one. I just bought this Tahoe and I don't know if it's wasn't working before I bought it. All tubes have coolant running through them so I'm wondering if the actuator or the controller in the back are bad... From one thing to the next. lol...
Black Limited
I did the same repair on my 05 Sub, cut both aluminum lines, one had a pin hole in it...………….
Cut out section to give me more flex, lower then you show in the picture, also double clamped for safety.
The black " T" plastic connector has a different angle going down.
mijohnst
mijohnst
Hey, good idea. I think I'll go back and double camp mine too. It sure makes it easier getting those suckers in. lol
Lukestdenis
