Grade 8 bolt from local hardware store, 9/16" if I remember right, but don't hold me to it, by however long u want it. Like said, easy fix but annoying. Relocation brackets aren't holding you up from being lower. Did you move over your sway bar so it clears panhard bracket? hard to tell from pics. Could be your air shocks holding u up tho. but Idk, never dealt with air shocks on my ride, so others will know more. Why not do rear lowering shocks while doing everything else? I run lowering shocks so don't use shock extenders, no issues. but having stock shocks could be issue. Again, others probably know more about it. Good luck with it bro, does look better being lower.
