do you have the auto climate turned on?
See what happens if you turn it off, maybe the sensor is bad.
Sounds like you did everything correct for the rear actuator. Front actuator may not be the same. Only way to tell is to tear into it. You only have 2 hot/cold actuators up front if you have the dual climate control.
