K2 Kaiju
The Depths
Lows: https://www.amazon.com/gp/product/B07GKPR452/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Highs: https://www.amazon.com/gp/product/B07GKC818Q/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Fit perfectly under the dust caps. has about a 4" pigtail to tuck into the housing. Plug and play! Pay attention to the " +/- " stamped on the connector, it can go either way. + is the white wire on the wiring harness. Also, the actual "unit" is adjustable, so make sure that the 3 prongs click into place as designed and the LEDs are in positioned correctly. wiring off the fan should be at 6 o'clock.
There may be more expensive or brighter bulbs out there but the lows are plenty bright and honestly anything is better than the halogens. The fans are not noisy, can barely hear them with the truck off.
Ill second on noisy hakari fans - got those same ones in lows and fogs too so its a hum fest, but light is easily worth it. I will say I plan on keeping the brights stock. My setup has all 6 on with high beams, and the slight yellowish of brights fills the spectrum on wet black roads making it easier to see. Unlike the stock lows, the highs are pretty decent, YMMV...
Sent from my SM-T580 using Tapatalk
LT1ZOB
Thank you guys. I’ve got a pretty mean light bar I installed behind the grille, so not worried about my high beams, but the factory halogen low beams are useless. Ordered the Hikari.
LT1ZOB
Hikaris came today. I installed them. What a difference. Thank you guys.
LT1ZOB
Night time pics? Thinking about buying some DD LEDs
It’s hard to tell in this pic, but I took it after replacing the driver, while leaving the passenger OEM halogen. Amazing difference. Just drove home from a client meeting in the pouring rain tonight
LT1ZOB
Getting ready for a new hauling trip tomorrow, will show you what’s loaded on it on the way back
Staggered 02
Color matching for the Escalade components completed and ready today. We had switched priority as I needed other parts first. Problem sovled by completion of all parts needed for the Escalade and the Duramax. Escalade parts will not go on until I am back in Florida next month or the following. Thus, the install is pending.
evotune
