Da90
Tulsa, OK
Damn I like that roll pan. Which one is it? Any other pics?
I have no idea what roll pan besides it is fiberglass. When I bought my house from my cousin and it was in the garage. I got rear ended while my truck was in the body shop. So I decided to put it on.
Before third brake light...
Fosscore
Truck is looking good man.
Five
North Carolina
4 hi mod, repaired key fob, and fixed the power mirror switch. Five channel amp install coming this weekend and a virtual laundry list of mods to come since I inherited my '02 Suburban LT 4x4 from my wife.
MinnYukon
Got some work done on my 04 Yukon. Replaced leaky intake manifold gaskets, upgraded to an AEM air filter, and installed the Airaid intake tube.
shakedown067
New sub box for an 8" sub. Now I need a better woofer. Of course it still needs to be covered.
Yukon Lover
Maine
Knock sensors done already? If not definitely would have done those while you were in there.
Sent from my Z797C using Tapatalk
Matahoe
Grand Rapids, Michigan
We had a bad gas smell coming from underneath for months. Fearing the worst I took it upon myself to remove the tank to inspect everything. Long story short the pump was severely corroded to the point of leaking. It was a bear to replace. It needed new connectors and such. Luckily I got a good price on an identical Bosch unit. Guessing we saved at least $500 easy. I wish I would have taken pics.
Since it was up a bit on jacks we also changed the Autotrak II fluid in the NP8 transfer case.
Rivieraracing
Bought an OEM electric fan harness from a member on here (thanks again TJD3004) to replace the LS1.com fan harness I've been running with for some years now, just need to find 2 replacement fan plugs for it (don't want to cut up the LS1 one if I don't have to) and find the time to install it!
DarkBlueHoe95
West Columbia, SC
New to the forum so this is my first time posting here so ill just post what ive done recently
6000k 35w low beams and fog lights
GoRhino brush guard with the guards removed.
24 inch single row full spot led light bar
led projector style bulb reverse lights
4hi mod
Park/Turn signal mod
led tag lights
led courtesy, door, and map lights
tinted tail lights
now that ive posted here all be back with updates and will be reading everybody else's posts
LittleFoot
