treehan77
TYF Fiend
Crestview, FL
replaced the two burned out bulbs in my digital ac control. radio shack only had two bulbs. so of course i find out there is actually 4 out inside. i guess i suck at soldering, cause now theres another bulb out that worked when i had it on the bench. oh well, guess i'll do it again when radio shack restocks.
elcapitanmas
just finished chasing down a coolant leak (quick connects at heater core) new powerstop rotor and pad kit front and rear, new master cylinder and a couple front suspension fixes (pittman arm, ball joint, tie rod) not cheap but needed to be done. rides and stops like a dream now
Boxdgm
MN
Did some maintenance and spring cleaning today. Replaced both hubs, pass outer tie rod end and idler arm. Then i cleaned the MAF and throttle body and sucked a can of seafoam through the brake booster vacuum line. Handles much better and runs smoother now.
#1taho
5150TAHO
niagara falls ont
Got may stainless steel brake line kit yesterday and starting to install it today. Looks like a lot of fun
elliotte08
