bottomline2000
Dallas, TX
Got some weathertech mats. Not impressed especially for the price. Dont really fit and the bottom is smooth like a surfboard. Perfect for kids playing in snow. Going to send the back and get some Lloyd's Veloutex mats. 20170212_135144.jpg
Sent from my SAMSUNG-SM-T377A using Tapatalk
BigDaddy13440
Rome, NY
currently I'm Almost up to date with maintenance on my daily driver and project. I recently replaced the front brakes and rotors. Finally found the water leak behind the rad shroud in a seam of the radiator. Sooo, that was a can of worms.. Replaced Radiator Therm, intake bypass hose, heater core and blender door actuator All last month.
I just finished a tile job for labor on my front end ball joints, control arms ends, etc... and just received my Black shocks in for this weekend it was to be done, but sadly parts held up due to bad weather.. I JUST FOUND OUT THAT WALMART SELLS MICKEY THOMPSON TIRES 285 75 16--$137.50
Sooo 3" lift and tires coming within a month or so. and they sell Nittos..
I was able to clear 285's on 16x8 rims with a +6mm offset (stock was -25mm, so they stick out about 1 1/4"), by simply turning my stock keys (got about 1 1/2" out of them). I also trimmed the plastic inner fender liner behind the bumper.
I later added older Ford Expedition lift keys, just installed and bolts turned until they make contact, I got 2 1/2".... I turned them in a bit, and got another 3/4" - 1" before they hit the bumpstops, then backed off the bolts a turn. In the rear, Z71 springs got me about 3/4" - 1", and 2" spacers got me to my current height.
That's a STEAL for MT's at that price! Grab 'em while you can!
Just ordered some Taylor LS race wires. Checked out the ones you mentioned @bottomline2000 , but the boots look the same as what I have, boot length is too long and that's what's burning on the headers, also some of the fiberglass boot and wire heat shields. And some Jimmi Jammerz. That's the steel anti theft plates that go behind the door locks, inside the doors. Later on gonna get them for the rear doors and hatch.
Cattivo
The Concrete Jungle
Anytime i park in Manhattan i pop the hood and remove the ignition relay...nothing worse than a thief
bottomline2000
Dallas, TX
Yeah the wires are shorter but I think the boot length is the same. The fiberglass boots will keep the wires from burning. My driver side header is weird with a big hoop and long wires just won't work for me. Talk about a crazy design..Screenshot_20170212-151926.png
I looked at those Jimmi Jammerz too. Need to get them installed..especially the one for the hood.
Yeah the wires are shorter but I think the boot length is the same. The fiberglass boots will keep the wires from burning. My driver side header is weird with a big hoop and long wires just won't work for me. Talk about a crazy design..View attachment 74469
I looked at those Jimmi Jammerz too. Need to get them installed..especially the one for the hood. I really hope the wires will work for me. Don't know if I mentioned it, but gonna see how much a custom prop shaft will run.
I usually park in parking garages but if i'm just double parked to run into a store my 120 lb pit bull detours thieves :)
120 lb pit? Dude, you gotta post a pic of him!
Didn't know they had it for the Hood too.
#1taho
5150TAHO
niagara falls ont
Here's a pic of my old fuel pump. I didn't post it when I did it. IMG_5388.JPGNot much left of it. The lines were swollen with rust and the pressure line had a pin hole. JUSt enough to smell it but not enough to see a leak
mgladdis
