Replaced front diff, rear diff, and transfer case fluids. Tried to do a transmission fluid change, too, but ran into some problems. First the drain plug was completely rounded off and torqued down waaay past spec. Then I figured I'd just drop the whole pan instead, but couldn't figure out how to get the shift linkage bracket out of the way. So I ordered a set of nut extractors for the drain bolt, and think I might end up dropping the drive shaft to get access to the top mounting bolts for the shift linkage bracket, unless anyone else has a better idea how to get the pan down.
I think you should buy my Derale trans pan with extra cooling and fluid capacity that's in the classifieds.
05Single
afraid of the dark
Went to the salvage yard in hopes to find a cubby for the center console to replace the pointless rear entertainment.
But all I found were jump seats and consoles with the same radio face as what I already have.
Plus everything was covered in 4' of snow so I just went home cold and empty handed:(
gtrslngrchris
Just make sure you tuck it inside the console because if you unplug that your rear speakers no longer work and I think that includes the sub inside the console as well.
After work tonight I decided on the rear driver side cubby for mounting my cheapy sub amp that's powering the factory Bose sub and cut a hole for it. I'll need to put 90 degree RCA adapters on it to make it fit but once those are in it should fit great. I finished up the night with a 3rd brake light replacement and putting the back half of the interior back in the truck for the first time in 3 weeks.
05Single
afraid of the dark
Really ? Hmmm I'll look into that. Thanks for the heads up.
Edit : Crap, says cubby/pocket is discontinued.:(
http://www.tahoeyukonforum.com/threads/center-console-rear-radio-controls-delete.24342/page-2
gtrslngrchris
Definitely works that way for my '05 LT with the Bose system and the same for the '07 Classic I tried the same thing with. That said, I also plan to "delete" the rear entertainment with the cubby like I did in my 2500 but since I'm still using the Bose system I'll just hide the rear entertainment module inside.
05Single
afraid of the dark
Still looking for a write up. There has to be a way to loop a few certain signal wires and tuck away just the plug.:shrug:
jarydM
Lost in the Woods
Tennessee
Replaced the crappy Clarion door speakers with new Rockford Fosgate 6.5'' front/rear door speakers and a new Kenwood HU...a little advice, never order things online after drinking a shitload of beer, i ordered 8- Rockford Fosgate speakers by accident thinking each box only contained 1 speaker in each lol...i now have 4 extra speakers if anyone needs them :D
How much? Lol
bobwit2bs
