95escahoe
ScottyBoy
Shreveport, La
That's how mine is. You wouldn't by any chance have a link to the socket you got do you? I was looking locally but I can only find 3157 and the DRLis 4114. They look the same I'm just not sure if there's a difference
I just put LEDs in there but only 1 works
No, I did NOT replace the socket yet. What I said was that I replaced the bulbs, and as I was replacing them, I noticed that the socket us so burnt up now that the bulb doesn't work, so I HAVE to replace the socket at this point. I've known this for a while though so it's not a huge surprise.
And as far as the bulbs, I've been using 3157's in my DRLs for the last 10 years. The base on the 3157 is the same as the 4114. The issue with the burnt DRL sockets seems to be a common occurrence, but I have also heard that it's caused by using 3157s instead of the 4114 bulbs. Who knows....
ScottyBoy
Shreveport, La
Question for those of you who have a 03-06. Do your map lights come on with the interior dome lights when you open a door? My map lights on my 2001 ONLY operate on the button right next to it in the overhead console.
Thinking about doing a write up on integrating them into the dome lights.
kwOH
Banned
I think the 00-02 was like that, my buddys 02 burban does that.
Bombsquad85
Northern VA
Pretty sure none of the lights came on with my 01 tahoe. But all my lights come on with my 05 denali
PG01
Up here to the right
My 01 only came on w/ buttons
TwiztidPixel
Anderson, SC
Well replacing the IACV didn't fix my cold idle issue so I took the throttle body off and cleaned it... it was pretty *****. Also cleaned the MAF while I was in there. We'll see.
Ran it through the car wash for the first time in a couple weeks since it was warmish.
Also made and installed a factory amp bypass harness. #worthit
gordo214ace
