Yeah dude I think both sides on mine broke at the very back towards the firewall and maybe even the ones in front of those it had a bad exhaust leak so I grabbed a ratchet to see if I can just snug them up and as soon as I put the sock it to them they just fell right out like they were sitting in their dead. My dad owns an auto shop here in town and he said that's common for these things.
Dorman makes a clamp for those broken exhaust manifold bolts that actually works pretty damn good if it's one that you can't drill out.
M1Gunner
Gainesville, Fl
Not today, but took Big Red down to Cedar Key on the 4th. First time ever being down there. Took about an hour and a half drive from where we live in Ocala. Really cool place. Definitely going again.
One a sidenote, the old 'hoe did great. There was one instance of the transmission being weird though. Stopped at a stopsign and the transmission didn't shift down into 1st. Only did it that one time on the way there and hasn't done it since. Maybe time for a filter change?
Nice rig, neighbor!
Appreciate it brother! You as well.
ItsJuniorJ
2005 5.3L Tahoe LT
Rear crank seal
Oil sump gasket
Engine oil change
Rear Diff gasket
Rear Diff oil change
Body mounts
Engine mounts
Transmission mounts
Bump stops
Various bushings
Front rotors + pads
Rear rotors + pads
Rear brake shoes
Parking brake cable
Header bolts
Header gaskets
Battery
PG01
Up here to the right
2005 5.3L Tahoe LT
Rear crank seal
Oil sump gasket
Engine oil change
Rear Diff gasket
Body mounts
Engine mounts
Transmission mounts
Bump stops
Various bushings
Front rotors + pads
Rear rotors + pads
Rear brake shoes
Parking brake cable
Header bolts
Header gaskets
Battery
Pics or it didn’t happen
2005 5.3L Tahoe LT
Rear crank seal
Oil sump gasket
Engine oil change
Rear Diff gasket
Body mounts
Engine mounts
Transmission mounts
Bump stops
Various bushings
Front rotors + pads
Rear rotors + pads
Rear brake shoes
Parking brake cable
Header bolts
Header gaskets
Battery
That's a whole lot of parts.
inmypassatlife
2005 5.3L Tahoe LT
Rear crank seal
Oil sump gasket
Engine oil change
Rear Diff gasket
Body mounts
Engine mounts
Transmission mounts
Bump stops
Various bushings
Front rotors + pads
Rear rotors + pads
Rear brake shoes
Parking brake cable
Header bolts
Header gaskets
Battery
How'd you know? C'mon over, I'll buy the keg and bring you drinks as you work on my truck
inmypassatlife
So, maybe I don't need a new trans...
Noticed in the last week the locks cycling as I drove, last Monday the truck wouldn't respond to my aftermarket alarm and being an old installer I realized the oem actuators "fell asleep" (I remember it being an issue in the bay years ago when the NBS first came out)....still having a stumble from a dead stop, but was occurring in all gears so I knew it wasn't gear related/was something else. No codes thrown on a cheap handheld or through Torque app.
So, I realized while on my second 3hr drive this week that the trans would shift fine for awhile and the locks would cycle and go back to the crappy stumble. Checked all fuses, all good...removed TCB and ECM fuse under hood for few minutes, reinstalled, and tightened down ground cable at battery. Seems to have worked for now.
May need to finally get a post mount battery and do the big 3....cheaper than a new trans
Cliffs notes: bad battery ground, ****** shifts due to BCM resetting due to said ground cable, truck shifted perfect last 50 miles of the trip and on side roads from a stop....keep fingers crossed.
2005 5.3L Tahoe LT
Rear crank seal
Oil sump gasket
Engine oil change
Rear Diff gasket
Body mounts
Engine mounts
Transmission mounts
Bump stops
Various bushings
Front rotors + pads
Rear rotors + pads
Rear brake shoes
Parking brake cable
Header bolts
Header gaskets
Battery
The thread title is "what did you do to your NBS/GMT800 today" and I'll bet all that didn't happen today lmao. Unless you had a small army working on it. How long did it take?
MrBalll
West Texas
Changed out the washer fluid reservoir for the third time in the eight years I've owned it.
DT360
