Ummm, no....you make it sound like you got it from a "guy" on the corner lol im thinking its something close to that some how...![]()
Ummm, no....
Ummm, yes.so your saying the tahoe passes state inspection?
Got me a 2020 NJ inspection sticker.View attachment 209388
Finally got to the trans fluid and filter change. AC Delco Dexron VI from Amazon. AC Delco filter and seal #24208576 (I didn't use the pan gasket).
Fluid was DARK.
I did remove the linkage bracket (driver side, T40 torx) and the heat shield (passenger side, 10mm). Pan came down easy peasy. No prying, pulling, or anything. Just the right angle and down it came.
Pretty good bit of sludge on the magnet, but no shards or chunks...
All cleaned up and Lubelocker gasket...
The filter seal was hard to get out, but I managed to get an edge bent away and got ahold of it with a little pliers.
Since BlackBear is in two weeks and I had the fluid out, I decided to make a day of it. You guessed it, Vette servo! Followed this:
https://www.performancetrucks.net/f...22/corvette-servo-install-w-alot-pics-476223/
Went as planned. I didn't get any pics of this because it was getting dark and started raining. I was going as fast as I could while still respecting the fact that I was working on my transmission. Getting the snap ring back in sucks.
Finished the flush and used the stick to get the level close. I put it through all the gears in idle and double checked. Then I took it around the block a few times. 1-2 shift is nice. With the little sprinkle going, it even got loose for a sec at WOT. Sweet. So far so good.
Got home, put it through the gears in idle again, rechecked the fluid level, and topped it off. Will check hot again tomorrow. Follow up later.
Where'd you find that lubelocker gasket? Got a link for it?
We are fixing to service the transmission on my son's 99 Silverado and I would rather get that gasket if we can. Hell, I want one for mine too even though I don't need a transmission service for at LEAST another year or so.
Did the 4hi mod in preparation for my retrofit. I followed this walk through and it was super easy and best of all free!
Did you do it so your fogs come on too?
