Fosscore
Same battery that had that corrosion issue on the terminal?
Nope. That was the Suburban and it got a new AGM battery. No issues now.
Tahoe diagnosis TBD but that cold front is getting down to 48-50F tonight. Might be too cold to mess around with it....
:lol2:
:lol2:
That's cold? Lol. Here's the temp in my bedroom the other night. Bedroom is on the right, the left is outside.20181123_204159.jpg
Now that's my kind of weather! Don't forget, that's IN my bedroom. Sweet.
M3kanic
Positive pressure? What’s that, on a traditional shock that has no air in it? I have Bilsteins too. They do not change how high my truck sits, believe me I know. I was running 26’s with close clearance to the fender, went from totally worn out shocks to new Bilsteins. Didn’t gain a fraction of an inch. They’re just dampers.
I was running the dodge 1500 bilstein that are always under pressure. It is a hydraulic shock. But it does more than dampen. The ones I installed raised my front about 1/2" and rears closer to an inch. Running a shock for lifted vehicles is completely different than the needs of a lowered one.
Fosscore
Jackwagon. It's 18° here.
Yikes. I’ll drive that wagon anywhere it is above freezing!!
That's cold? Lol. Here's the temp in my bedroom the other night. Bedroom is on the right, the left is outside.View attachment 211401
A/C still set but won’t go off tonight. Be back to near 80 by Friday and 85 by Monday. Sigh.... the 2 seasons of Florida.
Just changed the air filter too. Damn dogs hang out next to the return and it sucks the dirt and hair in all the time.
PG01
Up here to the right
Brrrrrr, thats cold......lol
HiHoeSilver
Away!
Chicago
The two seasons... 80 & 85?
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Went out to start the 06 last night after getting back in town with the 13. Truck had only sat for 3 days since last drive. No previous issues.
Doors unlocked with the fob, interior lights came on, turned the key, barely cranked, clicked, tried to wind down to nothing, clicked then started to crank and fired up. Voltmeter read 14. Let it run, then let it sit for 2 hours.
Same scenario. Took the battery to O'Reily's late last night to charge and test. Report is 1/4 life left. Interstate battery is at its 5 year mark currently and never given me trouble.
I ordered a battery on Cyber Monday just in case since it was $40 off, but a similar situation with a friends Yukon led him down this path. He replaced the battery, the alternator and finally found that it was likely the starter in the first place even after he switched stuff out.
I thought about trying the Suburbans new battery (different size and top mount as compared to the Tahoe side mount and tight spot next to the fuse box) just to see if that might give me another look before I buy that new battery or go down the new starter route.
Thoughts and input welcomed. Thx.
I love Interstate Batteries, but every single one I've had has done that. They don't really taper off, they just perform right up until the end of their lifespan and hit a brick wall.
Fosscore
Got 5 years so no complaints on that one. Will update in my build thread shortly but that Interstate was turned in as a core.
Rawaf
