Would like to see a review of these.Purchased a set of Eibach front and rear sway bars.
Messed with the HVAC
No front heat on my '01 SLT.
The rear heat works so I know it's not the core or coolant related, so I tried the actuator relearn procedure. I can hear the actuators move when moving the dials, but still no heat. I'm getting ready to remove the cover under the dash so I can visually watch the blend door actuator and tey to figure this out.
2001 Yukon SLT
2012 Yukon XL Denali
2011 Yukon Denali RIP 5/20/18
Yeah, my bad! It would be kinda hard to use the front heater core for the rear heat unless there was some crazy ductwork thing running back there from the dash.... LolActually it CAN be heater core related. The front and rear have two separate heater cores. But if the rear is getting hot, you at least know it's not coolant related. Either the front heater core is clogged or its something to do with the blend door most likely.
Made that mistake 1st time I changed the oil. 4.8, 5.3 and 6.0 all take 6 qts. Not sure about the 8.1 tho.gave my hoe its first oil change by me. bought it last dec it just had a oil change at the dealer, put a measly 1200 miles on it since i bought it. oil change due to time. got to love that.
the 5.3 took a 5 qt jug and a another qt. didnt think it would take 6.
alsp did my regal and my friends 300c 5.7 hemi, that thing took 7 qts to fill. regal takes 4.5 qts.
Yeah I didn't realize that when I changed the oil in the 'hoe last week. Bought a 5 qt jug and a filter and thought I was good to go.... till I got home and saw that it required 6 qts.... then of course had to go back out for another measly little qt.![]()
i got lucky, had qts laying around
