DenaliReyes
Detroit, MI
DenaliReyes
Detroit, MI
I recently changed the canister.
Mainly because I kept getting a p0455 code, also changed the purge valve and the vent solenoid, also the gas cap.
One pic shows a line that I noticed had charcoal pellets inside when I took it off.
It sucks if i have to take down the gas tank. Prolly run a vacuum and hope that picks them up 20200519_122044.jpg
View attachment 248034 View attachment 248035
It sucks if i have to take down the gas tank. Prolly run a vacuum and hope that picks them up View attachment 248036
You can disconnect them at both ends and use an air compressor to blow them out.
I changed the front and rear suspension. I think I put the bypass modules on the wrong place because inkeep getting check suspension on the dash.View attachment 248037 View attachment 248038 View attachment 248039
The resistors connect across the 2 wires that go to the connectors at the top of all 4 shocks. The fronts have a weird looking connector. Cut the connectors off and wire resistors across the 2 wires. At all 4 shocks.
Replaced driver side mirror. But asking for a refund because...... lolView attachment 248040
Some of the aftermarket ones are like that but I know how expensive the ACDelco ones are. You might not have it snapped all the way in. Try getting one hand behind it as much as possible and push all around on the center of it from the outside, or try to look in there to see if one of the clips isn’t snapped in. Sometimes you think they’re all snapped but they’re not, which causes the funhouse effect.
DenaliReyes
Detroit, MI
I contacted the ebay vendor and they gave me a refund and was told just keep it. Lol funhouse mirroring for a while then. I might take it apart and see if just the mirror can be placed on the oem set. Will see.
Try removing it and reinstalling it. Like I said sometimes it’s the mirror, sometimes it’s not snapped all the way in, so check your work.
macking
