mattbta
Frisco, TX
Got it put back together with all these parts. Started right up! Now to drive a bit and make sure I don't lose coolant. Then after a couple oil changes, send out to Blackstone. Idle is still a little rough and hot oil pressure around 35 but I didn't expect improvement since this was just top end stuff. Might do an oil pump at some point, just hoping there isn't bearing wear.
1 706 ADV CYLINDER HEADS 706
1 6504 MOREL LIFTERS
2 MAH-54441 CYLINDER HEAD GASKET
1 RNB-56390 COOLANT BYPASS SEAL
1 LIL-44180 FAN CLUTCH SPANNER WRENC
1 ICB-551696 BOLT KIT LS HEADER
1 FEL-61070 TB GASKET
1 FEL-72401 PICKUP TUBE O-RING
1 MAH-VS50250 VALVE COVER SET
1 ARP-912-0011 CLEANING TAP FOR LS1
1 ARP-912-0001 THREAD CLEANING TAP
1 ARP-134-3610 GM LS2 HEAD BOLT KIT
1 RFL-2008 EXHAUST GASKET
1 ADO-213-363 ENGINE CAMSHAFT POSITION
1 ADO-D8055 ENGINE OIL LEVEL SENSOR
1 ADO-213-4514 ENGINE COOLANT TEMPERATU
1 FEL-OS30693R OIL PAN GASKET SET
4 12595365 VALVE LIFTER GUIDE
1 551733 LIFTER GUIDE BOLTS
1 PT1798 ECT PIGTAIL
1 F107SX DRAIN VALVE
1 551680 OIL PAN BOLT SET
1 DWA142TH TAP HANDLE
1 63880 3/8" TORQUE WRENCH
1 15179498 UPPER RADIATOR HOSE
1 56500 LISLE TERMINAL TOOL
1 CAPRI TWO WAY AIR GUN
2 41-110 DELCO IRIDIUM PLUGS
1 12563918 OIL LEVEL TUBE
1 11610259 COOLANT PLUG HEAD
rgosart
Put new brake pads on all the way around, adjusted my parking brake shoes, and greased the front end. Trying some Wagner Thermoquiet pads this time. I used AC Delco pads last time I did the rears and they made a lot of noise. Hopefully this fixes that problem!
1 FEL-72401 OIL PUMP
1 11610259 COOLANT PLUG HEAD​
That lists an oil pump, pan gasket and pan bolts. Did you have a shop do the work? If so, it looks like they did replace the oil pump. Edit: that Fel-72401 is the o-ring so that must be what got replaced?
mattbta
Frisco, TX
I did the work. I pulled the pan because it had a little bit of sludge on the bottom. So, for good measure (and it was cheap enough) replaced the o-ring and pan gasket even though they were a tad under two years old.
Loose_Gasket
