Yes it is, are they common for that? After a while it clogged up and stopped leaking.
Consensus about Dorman's parts is 50/50--with some parts being an absolute "NOT". Are you brave enough to leave it on since it stopped leaking? If it was me I'd change it. You know what'll happen--locally it'll be great, no overheating, no leaking, but as soon as you go on the highway on a trip the ***** will break! Causing you to get stranded. Me personally--I'd change it--while you can.
Bear77
South FL
DenaliReyes
Detroit, MI
Definitely will, i forgot to change the post it's not the "Y" it's the connector to it, which I also put new. Will change it, wonder of Oreillys will change it , since I just bout it this weekend. Either way it's coming off.
Those Dormans Y's are known to fail fairly quickly and leave you screwed on the side of the road. They are bad enough that they have singlehandedly made replacing the Y fittings a topic of great debate and some people go to the extreme of putting in expensive metal Y's. The OEM ACdelco parts are known to last 150k + miles. I would replace them with the real deal so you don't need to worry again. The GM part numbers are 15055342, 15055343. Amazon or Ebay carries them. Or take your chances with the Dorman but you have been warned!
Redfire Metallic
Got these 22” off a Sierra Denali recently. Truck looks wayyyyy better with these compared to the stock 17s.
RLyukon19
