Danny3737
The piston came out right after the rotor split, because the brake pad had nothing to press against. Because of the heat generated, you were really lucky that the leaking brake fluid didn’t catch fire. Thank God for dual reservoir master cylinders. Back in the “old days” you wouldn’t have stopped until pulled the emergency brake or hit something.
Not the angle, to me it looks smaller too. And another pic of the caliper. Seems like the caliper seized up and blew the piston...
What’s left of the piston...
wjburken
Eastern Iowa
That was not a rapid failure of the rotor. Here is what it looked like right before a fin pulled the piston out.
Bear77
South FL
Bear77 - You're going to hang that on the wall of your garage, aren't you ?
Will save it for when I do get one! Lol
Actually the backside brake pad or what was left of it, was still there. And no emergency brakes, those need to get done as well.
Just a thought, but I wonder if it got hot enough to compromise the wheel bearing
Didn’t even think about that...
Sam Harris
Texas
Been getting the service 4WD message pretty consistently lately, and interestingly, the tcase seems to start out in Auto 4WD rather than 2WD where I leave it. It goes away quickly, usually right after turning off, and then pops up again a day or two later.
Finally caught it with the tech 2, and I have a C0327 code, so figure I need to replace the actuator motor, or possibly the TCCM.
Also getting the loss of comms message, and it won’t actually read data from the tcase as well. Here’s a video when I try to read the tcase data:
my guess would be just the encoder motor I think they run about $160 for a REFURB
Coop68
