NoReverseYukon
NE Wisconsin
Finally determined what is causing the belt squeaking. The damned power steering pump pulley needs to be adjusted out approx. 3/16". This was a new one for me - never had one move before. Tool to do the job arrives tomorrow. If it had to move it in, I could have just used a 3/8"-16 bolt, nut and washer. But at least the threads are in good shape for a solid bite.
3/16" is a bit much, but I've aligned them with washers behind the accessory bracket. I don't know if they were deformed brackets or what.
ks03
Fool Excess Member
I don’t know about you but I’m not putting either one of those brands in a place that requires removing the transmission in order to replace.
But if you had to trust one... rear main or steering knuckle?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
@Tonyrodz
Sorry to bother so much, but what is the height on the front of yours from ground to fender lip. I have my appointment for the alignment at 2 but need to get this done before it. If I were to max out the keys on lift would that make the truck leveled with the rear
@Tonyrodz
I know it's in my build thread, but I don't have time to check it. Omw to the dr's and I'm starting to run late. I THINK the front is somewhere around 32"--but not positive, sorry. If you crank the keys up--I actually did it too--it'll bring the front up where you want it to be.
915_Tahoe
HELL PASO, TX
Thank you, ill check you thread and good luck at the doctor's
Hobbitsam
