Teamiez
Do not buy reman boxes, get a blue top or red top. They are a bit pricey but worth every penny
The redhead steering gears were a fail for me twice, literally 0 play & was very squirrly driving i actually felt very unsafe. They sent me another and it was the same thing. There was no ‘center’ which is what made it impossible to deal with as well. I would try a new edelmann or new lares from rock auto next if I got another. The GM remans got very sloppy after 5,000 miles as well.
TheAutumnWind
Power steering pump is the hydro boost pump so where was the leak?
In the booster. It has a weep hole where the case bolts together. Fairly common. There are 2 main gaskets there a figure 8 looking one for the case and a donut that seals around the piston. I pinched the figure 8 one time closing it up and I wrecked the other one another time. Didnt lube it up enough before closing it up. What I have noticed is there is definitely some variance between the brands.
NoReverseYukon
NE Wisconsin
With both remans and new being hit-or-miss, has anyone tried to rebuild their own? We can't do much worse than that.
Logan5
Albany, NY
Did a passlock bypass on my Tahoe today, getting ready for a remote start install. 3 wires going into the lock cylinder that is under the steering column cover. Was super easy. Tested resistance with an multimeter. Saw 1.8K. Have a box of resisters. Tried 2k but didn't work. Got 1.8K with 3 resistors in parallel. Wired it in and all good to go.
TheAutumnWind
Anyone know where to find a replacement retainer clip for the brake pedal to booster rod/brake light switch? I lost the damn thing.
Some pics I found on the net that are similar.
Teamiez
If I had the skill, time, and tools I would try. I have a delco reman sitting in my basement with 5,000 miles on it just sitting in the box after getting a low mile oem from LKQ
Google “ GM brake switch retaining Clip”. Everybody loses them. They’re available at every auto parts store for about $5. Dorman makes a replacement.
Ja1034
